Door Unlocks after closing?!!
elninoloco7
Car: 1990 Nissan 300zx, 2000 Infiniti QX4, 1995 BMW M3
So my buddy's Z door is possesed. When you lock the door (while the door is open) the second it closes it unlocks itself. There is no or never has been an aftermarket alarm on the car nor has an actuator been installed in the driver side door. Its a 1990 Twin Turbo ZX. However when the door is closed you can lock it and stays locked (when locking with the key or when locking from inside while door is closed) I noticed the little hinge that locks to the metal bar on the cars door way thing..when i take a screw driver and move that hinge on the door, while its locked, gets unlocked...what can cause this problem?
car nut
Car: GT500.
i noticed the same thing on my '91 na. havent investigated it though cause i just lock it from the outside.
phanatikz32
Car: 1991 NA to TT z32 biatch!
elninoloco7 wrote:So my buddy's Z door is possesed. When you lock the door (while the door is open) the second it closes it unlocks itself. There is no or never has been an aftermarket alarm on the car nor has an actuator been installed in the driver side door. Its a 1990 Twin Turbo ZX. However when the door is closed you can lock it and stays locked (when locking with the key or when locking from inside while door is closed) I noticed the little hinge that locks to the metal bar on the cars door way thing..when i take a screw driver and move that hinge on the door, while its locked, gets unlocked...what can cause this problem?
car nut wrote:i noticed the same thing on my '91 na. havent investigated it though cause i just lock it from the outside.
........you guys do realize in order to lock the car you need to get out of the car hold the outside handle open, lock the door, close the door, and then release the handle right? thats pretty much common knowledge with early 90's imports/sports cars.
elninoloco7
Yes but..it never did that before though....i was a little kid in the 90's didnt start driving till 2003ish
car nut
Car: GT500.
...yeah my car was manufactured about a year before i was born so...
haha thanks!
John1006
Car: 300ZX
Yeah i have a 90, my passenger does it, i havent tried that hold the handle thing yet thoEDIT: Yep that works lmao
skinZ32
Car: 1992 300zx 2+2
wait thats not the same with mine. i used to have to do the "lock and hold handle technology" in my 90 240sx, but not with my 92 Z i lock, close door and forget.
elninoloco7
lol noway..it worked...haha....yea i was born in 1988 so i was 2 years old when this car came out haha.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
technically, you were only 1 year old, seeing as it was unveilled in '89
phanatikz32
elninoloco7 wrote:lol noway..it worked...haha....yea i was born in 1988 so i was 2 years old when this car came out haha.
i'm 21 i was born in 88 also.
FusionR300zx
Car: 1993 300zx/1997 240sx
SAME.f***.. i feel like a scum bag now.. my cars almost as old as me..
FML.
tg
you gotta close it first then lock it mine locks both doors if you turn it backwards 2x.
MyFairLady_90
Car: 1990 BLK Nissan 300 ZX N/A
I just figured it was to keep you from lockin your keys in the car but i just lock it from the outside.
raremotive
Car: 04 Infiniti G35
They have been using that features since the early Z31's.
JBO's300Z
Car: 1990 300zx 2+2 Pearl White
Are you kidding me? Are you kidding me? Are you F'n kidding me? If you had to go to your computer and post this question to figure this out you should turn in your keys and go buy a Neon.
skinZ32
Car: 1992 300zx 2+2
tg wrote:you gotta close it first then lock it mine locks both doors if you turn it backwards 2x.
weird.... my driverside lock is broken , so i have to use the pass. door to lock and unlock. it locks and unlocks both sides with only one turn of the key. thankfully
car nut
Car: GT500.
JBO’s300Z wrote: you should turn in your keys and go buy a Neon.
is it an SRT-4? lol.
Earl Hammer
Car: 1992 300zx NA
My door sometimes happens this way. When I have the door open I lock it but it quickly unlocks itself before I can even close it. Also, sometimes it chimes after I turn it off and get out. The door will lock if I get out and use the key, I just wonder why the lock does that to it's self... Idea"s?
nissanfreak12
Car: 92 300zx 2+2 TT
You do realize this thread is almost 7 years old. Thank you for searching.
If the locks unlock almost instantly, its because the ignition still thinks the key is in it. Make sure you hear the click from taking the key out, then they should lock. That little mechanism sticks sometimes, just spray some graphite grease in the tumbler that should help.
budget300zx
Car: 90 300zx NA
I just lock mine from the outside with the key. It keeps me from ever locking my keys in.
nissanfreak12
budget300zx wrote:I just lock mine from the outside with the key. It keeps me from ever locking my keys in.
He is having the opposite issue.
zboot
For those having this problem, you're not an idiot for asking.
My 1994 300zx apparently has newer type locks where once you lock the door, it stays locked. It's only when I needed to replace the latch mechanism that I ran into this problem. I bought a replacement off ebay from a 1990. Turns out it has different behavior from the one originally in my car. I confirmed this by manually locking the old one - the unlock doesn't move. At first, I thought I'd screwed things up. I suppose this is now motivation to get a replacement battery for my remote.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Remote? Z32? Sounds like an aftermarket door unlock system since as far as I've ever known, the Z32 doesn't come with door or alarm activating remotes or controls unless installed aftermarket after purchase.
School me if I'm wrong boys....but doubt it, I've seen a LOT of Z32's and looking at my TT's original order form, there's no area to order any type of alarm or door upgrades.
Ace2cool
I believe it was a dealer upgrade option past '94. I've seen a Nissan keyfob on a Z key.
Zombiecheez8687
Car: 91 Z32 NA 2+2 5speed
I've had a couple Mazdas that did the same thing and my 91 does it too... I always thought it was a fail-safe thing to keep you from locking your keys in.
