CanuckQx4 wrote:ya dimmer at max, my dash lights and temp lights are all bright.
I dont know about the glove box light I'll check at break time, but my hazard and defrost defenetely work, but I dont believe the hazard light illuminates red if its supposed to??
Hazard switch should illuminate red, defroster white. You probably have a dead bulb in your hazard switch if it doesn't illuminate and the defroster does.
It's a bit strange that your window switch packs don't illuminate since those use surface mounted LEDs which should not burn out as incandescents may have considering the age of your vehicle. I'll try to see if there's a fuse which controls illumination, but that's probably not the cause since your instrument cluster lights up.
