Rex »
https://forums.nicoclub.com/rex-u6324.html
Thu Aug 26, 2004 2:12 pm
The only "sure fire" way is to remove the door panel and find the locking mechanism arm (which is most likely jammed or past the normal position). Now if the door is stuck locked and closed you most likely will not be able to do this, so your next best bet is to attemp to unlock the door (by either the key or interior "lock") while tugging (not too hard) on the inside door latch. You may want to roll the window down and have someone on the inside and outside at the same time.
Good luck.
