door speakers
VG33QX4
Car: 2000 Infiniti QX4
I am currently looking at two different door speakers
Rockford Fosgate Prime R1653 Car speaker
Mb Quart Fka116 6.5
just curious if anyone has these or heard of them and if they fit in stock spots without modification. thanks.
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
VG33QX4 wrote:I am currently looking at two different door speakers
Mb Quart Fka116 6.5
if they 6.5 they gunna fit.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
Yeah 6.5's will fit, i just put in kenwood kfc-p709ps in mine over this weekend, have yet to post up the thread but yeah they fit fine.
fueler
Car: 2 Nissan's
2 BMW's
ive got some MB Quart Formula FSA216 6.5" in my CRX, run off the deck, they just alright
ive got some JBL GTO component speakers in the QX4 that sound way better but maybe because they are on an amp
jroo
Car: 2004 Nissan Pathfinder
How hard was it to get the door panels off? I dont want to break any clips off the door panel. I need to replace the factory speakers, my drivers door mid seems to be gone. No real output compared to the right.
fueler
Car: 2 Nissan's
2 BMW's
its easy a couple of screws and a bunch of clips.
miamiheat3332
The fronts have 4 screws total you need to take out, then you just unclip all around, then slide it up a little and off,
Rear has only 3 screws i think that need to be removed along with some stuff unclipped then just unclip the door, slide up.
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
Make sure you've got a panel popper because if you don't pull the actual clip it will break the backer on the inside of the door panel which is nothing but glorified cardboard.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
No s*** eh, I was surprised to see ther wood thin mdf like crap that was my door panel, simply wrapped in pretty black leather lol
Clips break alot easier in the cold, try and get the car warm in a garage or something if its your first time ever removing it. Dont be discouraged if a few of them shatter or just break, there cheap and dont have to be bought from the dealership
DAiNiUS
Car: 1999.5 Infiniti QX4
One of my rear speakers is a little screwed up and I was thinking of replacing it with some 6.5 Alpines that I have, but Crutchfield says that these speakers will only fit with some modifications. Anyone have a pic of the door with the panel off? Also, did anyone have problems fitting 6.5's in the stock mounting bracket?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
DAiNiUS wrote:One of my rear speakers is a little screwed up and I was thinking of replacing it with some 6.5 Alpines that I have, but Crutchfield says that these speakers will only fit with some modifications. Anyone have a pic of the door with the panel off? Also, did anyone have problems fitting 6.5's in the stock mounting bracket?
I ripped off the plastic bracket around the stock Bose speakers for all four speakers and used those as ghetto speaker adapter brackets. 6.5" speakers fit fine with no other modification. The following pic is without the stock speaker adapter bracket, though, but it should give you an idea. The screw holes didn't line up perfectly without the bracket, but I was still able to screw the speaker in.
DAiNiUS
Sweet thanks for that pic. I'll try to install these Alpines of mine since one of the stock rear speakers is driving me nuts. One more question though; are the front and rear speakers identical? I would maybe put the fronts in the back and put the Alpines in the front if they are the same.
VG33QX4
Update. I purchased the mb quarts. To my surprise they did not come with speaker wire nor terminals to connect to the speaker
The question I have is. When I replace the door speakers. Should I leave the amp in order to power the factory tweeters? If so which wire colors and which is positive and negative. need to be cut before the amp in order to send to the door speakers.
I am assuming the tweeters are 2ohm. Therefore unable to be powered off the head unit. Thanks I have aftermarket headunit installed already. Thanks.
Towncivilian
If I recall correctly, the tweeters are 4-ohm. It's possible to wire them in series with the door speakers to achieve something other than a 2-ohm load, but I just left the tweeters disconnected in my case and bypassed the amp wiring and removed the rear stock amp from the quarter panel. All four of my door speakers have their own tweeters as seen in my picture above, so it's not too big of a deal. I'm not sure if you can preserve the stock amps in order to use the tweeters and just run your own speaker wire, sorry. Hopefully someone else knows. If you do end up using the tweeters, I highly recommend doing this mod as it'll lower their cutoff frequency and they'll produce more sound.
VG33QX4
Thanks. Anybody know the proper wire colors in order to jump over the amp? Thanks
Towncivilian
Your FSM should tell you. If you can't figure out the schematics I can take pictures of the required connections.
VG33QX4
I just figured somebody knows the wires that should be cut and jumped. I can figure it our with a volt meter but I just wanted a sure fire first time ease of install.
Towncivilian
Okay, I found them for you.
Front left: Purple & blue/yellow and light green & blue/green
Front right: Blue/red & blue/yellow and blue/green & blue/green
Rear amp: Pink & light green, blue & black/yellow (left) and light green & orange, purple & black/pink (right)
I believe these to be correct. Verify them at EL-151 and lower if you wish. I would remove the rear Bose amplifier, since you won't be needing it.
shelby500krz
Car: 2001 Nissan Pathfinder LE 2WD
I did what towncivilian did, use stock adapters and installed new alpine 6.5 speakers and unplugged tweeters. I ran all new wiring to a kicker amp.
VG33QX4
So what two wires to I connect from the harness. To my new speakersv? I can't make heads or tails out of the schematics
I reall don't want to run new lines. There must be a way.
Towncivilian
Connect your head unit as normal, and solder the wires I mentioned together (i.e. purple & blue/yellow are two wires in the front left at the amplifier harness).
VG33QX4
Ok so I finished it up today. Sounds amazing. Clarity, loud good mb quart fka 116 are impressive
Two wires come from after the harness on both sides. Purple and yellowish gold wires. Purple is positive. Yellow is negative.
The purple and gold/yellow wire go to the amp stock. Cut these from the amp harness and connect to your new speakers this easy mod bypasses the amps.
