door sill lights
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
jimbo409
Car: 2002 qx4
I just bought a 2013 jx35 and my drivers door sill lights up when I open the door but the passenger door sill light doesnt go on is it suppose to light up, is so does anyone know how to fiv this or do i have to take it into the dealer
Ilya
Might be a loose or rusted wire, etc. Pull up the sill and take a look. Worst case, take a look at the schematics available on this stie and see if you can troubleshoot.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Most of those sill lights are Nissan/Infiniti OE accessories and not factory, installed either at the port of entry prior to delivery or by the dealer prior to sale. If so, it will be wired into the accessory pre-wire connectors underneath the kick-panel trim. That will be the most likely spot for an open circuit. The quality of the work will depend on who installed it, and I've seen some pretty sloppy stuff over the years. Chances are it will simply be a bad splice or broken wire.
Return to “Infiniti JX35 / QX60 Forum”
