Door saggin
phatpat240
Hello I had a question about body adjustments.I got my car several weeks ago and the driver door is sagging just alittleIt doesn't look to have ever been in a wreck.My buddy bought a s14 about the same time and his door is the same way.I was just wanting to know if you can replace the bushing or bearing in the hinge? if anyone has any knowledge on this please shed the light.Thanks alotbwt they are both s14's
slo40
On my S13 you can just loosen the mounting bolts on the door hinge and move the door up a little bit then just retighten them. If this isn't enough adjustment you can always drill the holes a little bit bigger to get more adjustment.
DriftFactory
Car: Evil S13
The method that slo40 suggested will work for a short term fix. However, I've found that the hinge tends to loosen again over time. If you have the skill or time I would suggest re-welding the hinge for a long term fix.
phatpat240
I think I'll try the loosen bolt method.The door only needs to move up like 2mm.Thanks for the info guys
