Door Replacement
Ryman
Car: 2001 Infiniti QX4
I have some rust on two of my doors and instead of getting it welded i thought i would try the junkyard first was wondering if all R0 doors would work for my 2001 qx4 or do i need a door specific to my year? can i use pathfinder or qx4 doors what years?
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
You can use 2000 to 2003 or 2004 whenever the qx4's last production year was. Unfortunately, you cant use pathfinder doors even though they will fit fine for 2 reasons.
Refer to the picture below:
Reason 1 (RED ARROW), The pathfinder does not have the body panel down here pushed out like the qx4 does, so if you replace one door with a pathfinder one, and the other is a qx4 one, it will start looking like a 1990 honda civic with mismatched doors, and different colors everywhere, you get the idea.
Reason 2 (GREEN ARROW), Again the qx4 has enlarged fender flares, alot bigger than the pathfinders, which as you can see, the rear door is molded into the fender flare, which pathfinder doors are not, plus pathfinder doors also do not have the pushed out body panel as in reason 1.
All parts are mostly interchangable between a path and a qx4, except i think the only things that really arent, is the body panels. I mean they will bolt up fine, but for car appearance purposes, like i said it will start looking a honda civic with mismatched everything.
Hope this answers your question, so unfortunately your now limited to finding a qx4 instead of both cars.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
You know those door caps clip right on and off right?? its not an actual door skin, its a simple cap.
I believe you can buy pathfinder doors and place your qx4 caps on the doors and be fine, someone will have to chime in, but the door itself will definitely bolt up and fit perfect
Ryman
i don't really mind the mismatched look for appearance and like canuck said i think i can just clip the body caps on the new doors and eventually i'll paint the car if i get mismatched doors not unless i'm lucky enough to find the white exterior like i have. But as long as it's an R50 the door will bolt up fine?
