Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jan 09, 2009 1:02 pm
Replacing the bushings isn't too bad. Obviously you've done the biggest portion, which is remove the doors and the pins. Popping the pins out is a drift and a hammer away.
You'll need a fairly long drift as well as a wedge. I usually soak the hinges in penetrating oil and then use the wedge to seperate the bushing from the hinge by wedging under the lip of the bushing. Then you can use the drift to either push it out by the lip or from the inside of the hinge. The second bushing of the hing is easiest to attack from inside the hinge.
Sorry I don't have any pictures to give you.
But remember to order new pins and bushings to get everything back to being snug and tight.
