Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Aug 25, 2008 3:43 am
Most parts stores sell a door panel removal tool as well....they're usually under $5. It's little more than a flat piece of metal with a notch in it you use to get between the panel and the door around the plastic snap clips, and pry gently.
There's also a couple screws on the armrest that need to come out, and the same tool can be used to pop the little wire clip on window cranks if you don't have power windoes.
I call them "jesus clips". Usually when you pop them off the window crank, they go flying and you shout out, "Jesus!", among other things.
