Door Panels
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
powaysd
Car: 2004 Nissan Spec V
Can someone please tell me how to remove the door panel on a 2004 Spec V? Any help would be appreciated.
A.Tech
Car: 1998 Nissan Maxima SE Black on Black 5-speed, and yes. I know my avatar is a Gen 5... lol
Sentra right?
You gotta tell us the make not the trim.. lol I can't just make a topic and say my SE-R. and exspect it too be the Senta or say the Altima.
I know the Sentras are the only cars that say Spec-V but still just saying. It is a good idea for people who don't know.
Anyway it is easy. Around the handle there should be a screw and the door will be held by a few screws and uphostry snap pins. Anyway some cars are a tiny bit different but this guide will help...
1) Remove screw in door latch2) Remove two screws on side of door panel3) Remove three screws on lower portion of door panel4) Remove plastic tabs located in door jam area on panel5) Remove screw in pocket/handle. Once removed this will allow you to remove the inserted armrest with attached power window and lock assembly.6) Flip assembly over and remove the electrical connector. This is a lock tab type connector. Using your finger or screwdriver press the tab as you pull the connector away from assembly.7) Pull the entire door panel up and away from door.8) Remove the speaker from the door. (3 screws). Disconnect speaker wire from rear of speaker.9) Remove plastic tabs from left side of door. (These are where the two side screws attach through the door panel.)
nuts_and_screws
Yeah, getting around with the screws should be your way dude!
Return to “Interiors”
