Door Panels
powaysd
Car: 2004 Nissan Spec V
Can someone please explain how to remove the front door panel on a 2004 Spec V? Any help would be appreciated.
OneFastStanza
Car: '02 Nissan Sentra SE-R Spec V
'92 Nissan Stanza
'97 Nissan Maxim
'04 Saturn Vue Redline
'04 Ford F250
Ok well first you need to pull up on the door handle which will allow you to get to two screws and also allow you to pull up the trim panel around the window switch and allow you to disconnect that harness. After that there is only one other screw somewhere around the edge of the door and one other plastic looking screw. Also make sure to take off the trim around the door handle and you can get that off with a flat head screwdriver. When those are all out just kind of pull on the door to release the clips and then slide the door up to get it off a ledge at the top of the door. It is a pretty simple process.
