door panels off
electricproblem
i want to redo the cloth on my door panels but i cant get the panels out i got the little black part for the door handle and lock and the power window arm peice out but the whole peice itself i cant get out. any suggestions
rico05
Car: 1992 RMS13 w/ CA18DET
Did you get the screw out that holds in the little handle? It is under a little screw cover, so it is easy to miss.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
If you have an s13, take off the window switch piece and door handle/lock like you have, and the one screw in the front of the panel that gets covered up when you close the door. After that, grap the panel at the bottom (there is a cut out at the bottom of the door where you can get your fingers behind the panel) and pull. Its held on by clips the pop out when you pull on them. Then lift the whole panel up and out.
