Door Panel
Post all your Nissan electronics, car audio and stereo questions here!
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
hello, i am doing the 6.5 in the door mod on my s13 and i was wondering how the door panel comes off? i can only seem to find one screw holding it on... so after i take that off does it just pull off or are there any tricks to getting it off without damaging it? Thanks in advance
xckid
Car: 2004 Chevy Blazer ZR2
the door panel on the driver side pops off.. but first im assuming you took the one off nearest to the fender. after that one there is one in the arm rest? i guess thats what you call it , idk the part you grab to close the door lolsry. after that it just give it a couple of tugs from the bottom and when you slide it up you need to dissconect the harrnes for the switches. im assuming your window though is automatic.and then on the pass. side take off the ohh sh*t bar and the screw nearest the fender and the one inside that little door grab thing lol...ohh and you need to take of i belive screw behind the door latch then pop the plastic off just carefull you dont break it gl and hope this helps might be confusing
Tyler
Thanks man, that actually helped and i understood everything you were trying to say...
