door panel repair
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
wantz87
Car: 1990 240sx/stock v2.0
1998 GMC Sierra c1500
hey everyone, i have older door panels with the carpet crap taken off, but now the vinyl is ballooning away from the backing. anyone know how to fix this with out completely taking the panel apart?
AZ89two4Tsx
Re-upholster the panel. Most people do it themselves but I had no luck with it. I ended just buying a set of oem tweed ones.
wantz87
i know about replacing the tweed with a different fabric. i'm not looking to do that right now. but the vinyl is ballooning from the metal/plastic frame of the door. that is the problem i need to fix.
x240xdrifter
Car: 1991 Nissan 240sx
3m super adhesive trim spray
its all i need to say
wantz87
x240xdrifter wrote:3m super adhesive trim spray
apparently, yes, you do. expecially since i said that i don't want to take the door apart. i.e. maybe a heat gun/hairdryer could reactivate the adhesive... or something the soaks THROUGH the vinyl to the substrate....
x240xdrifter
oh contra, your talking about the balloning of the vinyl to interior door panel (metal/fiberglass or whatever it is.) rather then the tweed to the vinyl. What im trying to say is you is to use 3m Super Adhesive Trim Spray between the vinyl and door frame. There is no way to re-activate the adhesive or have something soak through. Your either going to have to replace the door panel or respray adhesive
Return to “Interiors”
