spec-v5150 »
https://forums.nicoclub.com/spec-v5150-u6046.html
Fri Sep 19, 2003 11:03 am
I "think" there are two screws/ I know for a fact that you have to pop a plastic cover inside the little pocket on the door panel and there is a screw there. i also think you have to pop a circular panel on the door panel and unscrew a screw there too. Cant remember.... Its been awhile but I am 90% sure. After that, I pushed up on mine and it came off. It may take some force but dont break anything. I dont really see a reason to remove the mechanical fan unless you you want to clean up the engine bay or it wont cool enough due to a turbo install?? Not sure why. I HOPE he put electric fans in its place somewhere inside that fan shroud that is still installed:rolleyes Fromw aht I hear it is kinda the same methodology as getting unorthodox pullies...frees up HP's. Probably very minimal and unnoticeable on an N/A vehicle. A gain I could be wrong. I only removed mine because when you do teh RB swap, it wont fit!!!!
EDIT: as corn said...gettign it back on is FUN. Be prepared to buy somemore of those little plastic pieces that will probably break...LOL. They are cheap at a local parts store. I bought some early chevy ones as they matched up well with the 240 ones
