Door panel Removal
gamecockQ45
Car: 1992 Infiniti Q45t
Any of you guys know how to remove the door panel of a '92 Q? I got all of the clips loose that hold the edge of the door on but cannot get the middle to let go. What's the deal with the arm rest and how do you get it off?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Slide the armrest back and it will reveal 3 screws.... Theres a 4th screw behind the plastic thing on the door...
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Be ESTREMELY careful removing the plastic switch plate. Try to "pop" the front out, and "slide" the rear forward to get it out. The arm rests are usually hard to slide back. Grab it with your fingers and pull. It should move back about 1" and fall off in your hand. Then disconnect all the wires, and lift the panel off the window rails. It is quite easy, once you get the switch panels off.
demhaizar
here is a very helpful link with pics
http://www.carstereohelp.com/s...e.htm
Razi
fayceoff
That IS helpful!! Thanks for that.
