Door Panel Removal - 2011 Quest
A forum for the Nissan Quest... minivan lovers unite!
mikedadrumma
Car: 2011 Quest SV
I will be having my door repainted this weekend because of someone keying it. I need to remove the mirror, door handle and the chrome trim. Does anyone know how to remove the door panel to get access to all of this?
mikedadrumma
Car: 2011 Quest SV
Just in case anyone ever will read this in the future, its extremely easy to pull the door panels off. At the bottom of the panel is a little "lip" that will fit your fingers. Just give it a good strong pull and the panel will just pop off. Work your way around the door...you won't break it.
Now my next "Quest" will be to find out how to pull the panel off of the sliding doors. I want to replace the speakers back there. Stock ones are horrible!
MinivanDad
Car: 2013 Quest S
Did anyone ever figure out the rear doors?
mikedadrumma
Car: 2011 Quest SV
MinivanDad wrote:Did anyone ever figure out the rear doors?
I'm still trying to figure it out. Would love to know how to take off the panel off of the lift gate as well.
MinivanDad
Car: 2013 Quest S
I'm having trouble with the front doors. Popped all of the clips, took a 10mm out from the door handle, but something's still holding on tight in the middle. Any ideas?
PapaSmurf2k3
Site Admin
You could try giving the factory service manual a look.
Here's a how-to for that:
http://www.nicoclub.com/archives/use-ni ... abase.html
Return to “Quest Forum”
