door panel carpet removal??
sgiovanni86
so i was readin a write up on removing the carpet from the door panels to just black plastic, i tried to remove mine there no black plastic behind it, just wondering if the convertibles were different then the hatches in relation to the carpet on the doors and the glove compartment
mrzabala
Car: 93 Nissan 240SX SE Hatch
The hardest part about removing the carpet is in front of the center console. You will either have to cut it or remove the dash and the brace bar going across (supports the steering column). As for what your looking for. Im assuming you mean the kick panel. It has plastic push in poppers. Just pull on quickly but carefully. The only difference I see with the HBs and converts. is the roof (and rear) and the extra bracing for the converts. Everything else should be the same.
sgiovanni86
i was talking about the actualy fabric on the door panel. sorry i should of made it clearer , thanx though .
mrzabala
Oh. Theres rivet plastic screw-ins that you remove. It should be behind the plastice trim pieces. I remember mine was pretty easy to remove until I got to the below the radio. Its really straight foward. Just look around, remove some trim pieces and you should be okay.
sgiovanni86
i meant that lol. theres a write up on how to romve that
and make it look like this
mine doesnt come off like that, the carpet doesnt come off the panel.
Rex
Car: None
sgiovanni86 wrote:i was talking about the actualy fabric on the door panel. sorry i should of made it clearer , thanx though .
Vert doors are different than Coupe/Hatch doors in MANY ways.
sgiovanni86
madcowvert
on vert door panels you cant do that you can only do it on coupe/fastback panels..
sgiovanni86
thought so i learned the hard way
madcowvert
lol you sould to coupe panle conversion.. there is a write up just search for it.
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
Vert panels need to be upholstered. There is some fabric backing permanently mounted to the inserts.
donmeca2020
Car: 2005 lancer evolution and 1993 240sx convertible
i also learned the hard way, im gonna have to go and either have them reupholstered or something.
ishkabibble
1997 Infiniti I30t
Do it yourself. It's incredibly easy.
