Door Noise
slaughtermimms
Car: '95 Infiniti Q45
'02 Ford F150
The rear doors on my Q......when you open them, make this sound that should not be in a Q.
I have trace down the location, and it come from door check I have lubed (mader better) them however you can still hear this metal to metal grinding .....both are also rusted real bad, is there a fix or do they have to be replaced? :confused:
Q451990
Use the nastiest grease you can find... stringy wheel bearing grease is what it looks like they used at the dealership. Nice white lithium grease and clear silicone sprays can make it worse!
Heath
