door locks
dsalguod
Car: 97 j30t
doors won't open with keys or remote 97j30t
Modified by dsalguod at 9:42 AM 10/31/2006
lovemyj30
Car: 1994 infiniti j30
mine just did the same thing i had to cut a 2 1/2 inch hole in the door panel 4 inches above the arm rest3 1/2 inches from the door jam then replace the panel
driverdriver
Car: NICO's longtime resident Canuck!!!
Welcome to NICO!!!
Do your door locks work from the inside?
jamaican
Car: 1996 infiniti j30t
I have the same problem with my 1996. how did you fix the problem?
f-dss
Hi, I have a 94 j30 with the ever so popular stuck door. It is the front driver's side door and I think the latch is frozen shut. I have a latch and actuator coming along with a slimjim kit. Does anyone have any tips on getting the darn door open? Thanks in advance.
DominickJ30
Car: 1993 Infiniti J30t
Yea give the door a couple good KNOCKS on the outside around the handle are, that always frees up the lock for me.
purplesignal
Can you open the door from the inside? If you can, remove the panel, and replace the latch. If not, you might have to do like me and tear off the panel...reach inside and manually force the door to unlock that way.
f-dss
Yeah, my door will not open from the inside or out, I guess I'll try not to destroy the panel too bad
DominickJ30
What is the problem exactly? The door locks, or the door latches? It wont unlock or it wont open?
f-dss
DominickJ30 wrote:What is the problem exactly? The door locks, or the door latches? It wont unlock or it wont open?
The door will not open. If I try to unlock the door with the power door lock switch, the lock will try to unlock and make a clicking sound but then return to the locked position. The same thing happens when I try from the outside with the key. I can manually move the lock lever to the unlocked position, but it doesn't unlock the door.
DominickJ30
Ok then take my advice and do this:
Go outside and put the key in, turn it to the right until you feel opposition, take it out and make a fist, with the bottom of your fist give the door a couple good KNOCKS on and around the door handle area, and try to unlock. If this doesnt work then try again. It took me a couple times to figure out on my car, but you want to hit the part of the door between the handle and back door if that makes any cents.
playland
Car: 89 240sx (DD) 95 240sx Se (current project), 07 Suzuki GSXR600
having same problem with my 95 240..drivers door is locked shut and no matter what wont unlock and door cannot be open...anyone find a way to get it opened without destroying the panel?
gr8scott72
Car: 1994 Infiniti J30t
playland wrote:having same problem with my 95 240..drivers door is locked shut and no matter what wont unlock and door cannot be open...anyone find a way to get it opened without destroying the panel?
I don't know how they did it, but the infiniti dealer got mine open and didn't even charge me an arm and a leg. Just an arm. Good thing it's an automatic.
kcbell77
Car: infinity j 30
I am having the same problem with my 97 j30. i cant lock the door or it wont open back up and now i have to knock on the door just to get it to latch every other time i close the door. Does anyone know what i need to do to fix it? I had to disconnect the automatic door lock because to was makeing the locks go crazy too.
TheJapJag
Car: 1996 J 30
f-dss wrote:The door will not open. If I try to unlock the door with the power door lock switch, the lock will try to unlock and make a clicking sound but then return to the locked position. The same thing happens when I try from the outside with the key. I can manually move the lock lever to the unlocked position, but it doesn't unlock the door.
(...nor does the lever stay in the unlocked position. It returns to "lock" position)Exact same problem here on my 95 J30 passenger door.
@ DominickJ30: Thanks for the remedy. I'll give it a try.
PS- Is WD-40 going to help this symptom, or will I need to replace a part?
yodawill2000
Car: 94 Infiniti J30
One of ya'll said the door unlocks then re locks by itself.Me thinx thats the Timer gremlin.Mine does it maybe once in every 20 openings.
