Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Apr 23, 2003 5:53 pm
You might check to see if your key is badly worn... especially on the tip - if so a new $25-30 aftermarket key may solve your problem. Typically the ignition switch is more of a common problem than the door locks, but they fail too. If the silicone spray fix doesn't hold - you may be able to have a good locksmith rebuild them (replace the wafers that act as pins) in the locks. Check for someone who does a decent number of high end locks that use the wafer keys. The parts for an entire new lockset is on the $400 range plus I'm sure at least two hours of labor. Definately worth trying a new key first. I had one locksmith tell me that the best lubricant is WD-40 for wafer locks, but I'm still not completely convinced.
Heath
