autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Mon Mar 03, 2003 1:30 pm
Having installed several door lock/latch assemblies for the same problem. There is a plastic bushing in the latch mechanism that wears out, the lever from the electric door lock actuator attatches to the latch at that point. The electric door lock actuator will get put into a position of either not being all the way locked or unlocked, when that happens, the door may lock or unlock on its own depending on the position of the electric actuator (will have a mind of its own). You can remove the latch assembly and inspect that area to confirm the diagnose before replacing any parts.
