door locks pop open when closing doors(already searched)
SR20drftSX
Car: 240 hatch(sold) , 92 Infiniti G20 JDM Sr20
i shut the door while the lock is locked and when the door closes it pops back to the unlocked position...both doors do this..they are manual locks , 89 fastback all manual , ..id really like to be able to lock up my car but these damn locks keep unlocking themsleves , and the key will not turn it either way
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
simple. Nissan did that to keep you from locking the keys in the car. Just lock it and when you go to close the door, grab the handle like your trying to open it as you close. The door will remain locked.
nissanfreak8
Car: 1989 240sx, 84 Olds Delta 88 R.B.LS, 1995 Chevy Lumina LS
If ur doors shut and latch fine other than that then i would have to say that ur door lock mechanism is prolly shot and its doing that to prevent u from getting locked out of ur car.
SR20drftSX
alrighty...ill have to try that...that doesn't explain the key not being able to turn the locks tho..ill have to try it after i lock it once...thanks again
ricebike
2002 Quest
2005 Altima
weird...
key excessively worn?
do you know the keycode & can cut a brand new key from that?
lube the lock cylinders?
but, the other thing that wa stated is just like that from the factory (other import makes did the same thing)
SR20drftSX
i lubed all that i could see..IE: the locking and door latch on the side of the door with silicone lube..i havent attempted the lock after that...and no its a brand new key..i had 3 of them cut
ISUJinX
This guys right.
wa-chiss wrote:simple. Nissan did that to keep you from locking the keys in the car. Just lock it and when you go to close the door, grab the handle like your trying to open it as you close. The door will remain locked.
BMAR240SX
Car: 1993 Nissan 240S Coupe
I have the same problem where i lock it inside and when i close it the door is still open.But i just lock it with the key.
SR20drftSX
id do that too but my locks wont turjn when i stick the key in
dsc4130
your locks are prolly froze and you have to hold the handle up then shut the door. its a nissan thing and has saved me from locking my keys in the car so many times
