Thebobb »
https://forums.nicoclub.com/thebobb-u312603.html
Thu Jun 20, 2024 5:48 pm
I have searched everyone and not found anyone with the same issue so here goes.
I noticed my car was randomly locking. It happens whether it is parked, or if I'm driving. Doesn't seem to be any consistency, sometimes it's every 10 seconds, sometimes once per hour. But it will continue to do until the car battery is completely dead.
My keyfob works fine, my keyless entry buttons on the outer handle work fine, and I can manually lock/unlock without issue. However, on both the driver and passenger inside buttons, when I press down on the "Lock" button, nothing happens. If I press the unlock button, it unlocks before immediately locking again, every single time.
I tried removing the battery from the keyfob and it still happens so not that. At this point, I'm leaning twoards the master lock switch on the driver side. Just wanted to see if I could get confirmation before I go ahead and order it. Especially because the passenger button is behaving the same. Possibly related, but my passenger door was full of water the other day. I removed the weatherstripping and drained it and it has been ok since.
Thank you in advance
