chimp wrote: ↑Mon Dec 13, 2021 6:23 pm
VStar650CL wrote: ↑Tue Dec 07, 2021 3:41 pm
Usually a bad lock cylinder switch in the driver's door.
Would this be the case if the same result occurs when pressing the lock on the passenger side too?
Yes. If the cylinder switch is falsing then it will keep telling the BCM to re-lock the doors when you unlock, or unlock when you re-lock, depending which direction the cylinder switch is failed. So the BCM will respond normally to either of the door switches, but then immediately obey the bad cylinder switch and change its mind.
