Blue85 »
https://forums.nicoclub.com/blue85-u140980.html
Sun Aug 16, 2009 7:19 pm
First off my advice is worth what you paid for it. I can tell you I have made many, many keys to maximas, of all years working as a locksmith. Every time I make a key to a maxima I will either remove the door lock or trunk lock.
Take the door panel off.
On the back of the lock there should be a plastic clip, which the lock rod attaches too. If it will turn both ways without locking or unlocking this is the problem. On the back of the lock itself, inside the door, there is a relay which clips on the back of the lock cylinder. This is what turns the alarm on/off. See if it is even still there, if not you will have to replace it, I have no experiance in replacing one. They can be easy to break, because they are made of plastic and getting them off can be tricky.
The key not working in the trunk lock is kinda common. Get some good spray lube, I highly recomend corrosionX, or wd40 will work. Liberally spray some in and work it in by running the key in and out alot. If this doesn't work the key may be worn from old age. Post a pic of your key and I can tell you for sure. If nothing else you could remove the trunk lock and take it with your key to a locksmith and let them deal with it. Not hard to remove it, just remove the trunk liner, disconnect the lock rod from the clip, remove the relay from the back of the cylinder, and remove the horseshoe clip.
If you still can't figure it out then take off the passenger side door panel and compare to see where the problem is.
I advise against a new lock set. Expensive, time consuming and you will still need a different key for the ignition. Rekeying/replacing the ignition is a PITA, its held in by roll pins that will need to be drilled to remove it.
Let me know how it goes.
