door lock problems
GregL
Car: 1990 nissan maxima 2001 audi A8 1993 gmc suburban 1996 ford taurus wagon
I have a 1990 maxima that the doorlocks don't do anything I dont here relays or anything I have located a few modules under the dash to the right of the steering column but cant tell if its bad or not I have ruled out the swith because i have a signal on them but the wires dont correspond to the wiring on the switch
Modified by GregL at 12:58 PM 9/19/2007
GregL
checked all modules for burnt traces still no luck I've tried "security module (left of steering column) timer module (Right of Steering Column) , Keyless Entry Module (Passenger Side Dash) Is there a power control relay for this setup? If so where? I've heard under the passenger seat under carpet If you have a schematic please attach itGregL
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
check the fuses it might be as simple as that
GregL
Problem found ! bad power window switch on drivers side also has power relay for door lock circuit built in it
