Door light
edogg27
Car: 2003 Nissan Pathfinder
i was wanting to add some puddle lights and was wondering where i can tap the power from for the lights to come on with the dome light.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
You can use a relay to actuate the lights. Tap into the "BATTERY SAVER OUTPUT" (pin 17 of the smart entrance control unit) to trigger the relay and get power from some other fused source (maybe the "ROOM LAMP" fuse behind the coin tray). I'm fairly sure that will achieve the desired effect.
edogg27
so run the positive to the secu or the room lamp. or will they both have the same effect
Towncivilian
A relay is an electronically operated switch. The trigger for the relay would be the BATTERY SAVER OUTPUT from the SECU - tap into this wire in order to actuate the relay when the door is opened. Have the puddle lights connected to the output of this relay so they turn on when the relay actuates.
You can use a T-tap to safely tap into the wiring of the SECU without chopping wires up.
edogg27
So i take the positive and wire it to both the fuse boz and the secu? Sorrry just kinda confused lol
edogg27
Sorry to bring up an old post but i just recived the puddle lights and i found the SECU. So if i have this right the SECU will make the light turn on and off with the dome lights. But to achive this i have to make the positive wire go to both the SECU And the FUSE? Or just the SECU. And if i have to do both how so? Im not really understanding exactly how to do this correctly.
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
Hi edogg27, what type of puddle lights do you have and where did you order them from? I am interested and like to do it if there is not too much involved. Thanks.
edogg27
They r from ijdm toy they are just led bulbs in 4 housings that I'm going to put under my car. They look like the ones the come on some Mercedes Benz vehicles. They are just a positive and negative connection so it seems easy but I'm not sure how to get them to work with the door light. That's the only thing
Towncivilian
All you should need to do is tap into the SECU's door switch wire and connect that to the positive terminal of the lights, then ground the negative terminal of the lights.
edogg27
Great I'm going to get right on that. Thanks a bunch town this is gonna look sweet
Towncivilian
Good luck, I'm eager to see the results!
QX4ME
11 MB C300 Sports
06 Honda Odyssey
I am not aware of any Mercedes-Benz having the puddle light under the car, not under the exterior mirror housing? Will it be good to put the light under the car so close to ground? And will shop lifter damage the light if they are not recessed?
