911/Q45 »
https://forums.nicoclub.com/911-q45-u148.html
Mon Dec 13, 2004 5:51 pm
Did an interesting little tweak over the weekend. The driver's outside door handle was a little loose, so I removed the door panel and tightened the 2 10mm nuts on the inside. It made it so solid that I did the rest of them too. I could only reach the front nut on the rear doors, but it still made a significant difference. As I've only got 85K on the car, I'll bet there's a lot of loose handles out there. I really appreciate how the car is designed to come apart and go back together gracefully. If I tried that in some of my previous American iron, things would be worse when I finished rather than tighter.
