Poyzinous »
https://forums.nicoclub.com/poyzinous-u125838.html
Sun Feb 08, 2009 6:35 am
Just so everyone could know, The 03 and 04 G35 has plastic trim colored like aluminum. The only real aluminum trim is the trim around the shifter. From 05 and newer, the trim is real aluminum. All the FX's got real aluminum. The panel is simple. Stick a small standard screw driver in the slot, and gently pry it back, do that with upper and lower sections. Careful, the plastic trims won't bend, but aluminum bends and is damn near impossible to bend back to shape. Unless you're Bender. But He's not real.
