When i looked at the door i saw the 3 screws holding on the latch that are on the door, and the two that hold thte latch on the car. None of those are adjustable and are all tight. Is there something else i can do or check?AZhitman wrote:You'll want to make sure the latch mechanism is secured tightly inside the door)... there's 2 screws on the inside of the door edge.
Also, the striker plate on the body may be out of alignment, but you can check that after securing the latch mechanism.
