door closed but light stays on
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
guys, in my 91 240 whenever i shut the door, the light on the dash stays on, that says that the door is open. and then the floor and celing light stay on, but the seat belts work, and they go back. I know it's not those black sensors with the boot over them, because i tried my friends on my car and they work on his car, but same thing happens on my car. it says the door is open.any ideas?
~swave
red_240_fastback
Car: '86 300zx turbo, 1989 240sx fastback, 1990 KA24DE 240sx hatchback
i would also like to know about this since mine does the same thing. i just turned the light off so it doesnt come on with the door
xyster
Car: '00 Prelude
mine has always done the same thing...I'm interested to hear how to fix this, too
Dattebayo
replace the switch/button in your door! :DSimple... The contact in the button is stuck closed.
edit: whoops, i didnt read carefully. Uh, i think hes right,V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V
KaDrifter
I would try to push the switches in on both sides with your fingers if the lights go out adjust the door strikers on the car in toward the center some, I think you need a T30 torx bit??
xyster
Car: '00 Prelude
the switches are fine on my car, the door just needs to be adjusted somehow. I've heard something about replacing the bushings, but I dunno
KaDrifter
I guess you could replace door pins and bushings(pita) but you could just adjust the strikers. Break the torx bolts loos move the striker in toward the center of the car a little until the light goes off and the door shut good. Just some trial and error
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
sorry to bring up an old post, but I really have had it with this problem!!!
I tried to see if it was the switches or the light switch up top, or even my alarm, i checked everything with a multimeter!!!
COULD NOT FIND THE PROBLEM!!!!
Did you ever solve the problem guys?
got2b240
I found my problem tonight with the dome light staying on and such.
If you remove the passenger trim above the door on the inside of the car. Its the plastic molding that the sunvisor practically touches. You will have to take off the 2 screws for the visor, and remove that, then pull/pry off the sunroff molding if you have one, and take off the molding behind that also by removing the 1 screw and pop off the front of that molding so you can remove the first molding i mentioned because it sits overlapping it. now you can pry down the roof trim and if you look towards the column that divides the window and that triangular glass in the back that says 240, underneath the roof pannel, you will se 2 wires taped around pretty crappy, and you will see a mount bracket for the auto seatbealts that has a sharp edge, now the wire is pressed up against that bracket im almost 100 percent sure!!! just tape it up where its rubbing real good so it doesnt happen again.
seems to me like they should have run the wire "behind" the mount for that assembly, but this should be it, unless you have a bad door switch.
-Chris K.240s maniac
