door chime
Nissan 350z / Nissan 370z general community discussion forum
_b.jaye_
Car: '03 350Z
anyone here been into the dash enough to get a good look at the door chime? specifically, the location of the lil' bugger and how / if its wired? i know about where it is, but im just wonderin if its accessible without tearin too much out. and if i can cut into the signal to just it, or if its powered off a chip board or something
reason im wanting to is, i was thinking of switching the wire to the chime so that when im cleanin the car or something id otherwise have the door open for, i can do it without the damn thing ding-ding-ding'in
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
not sure on location in the Z33 but follow the sound it should be under the dash somewhere, and should have a disconnect in the leads
or oyu can disconnect your door pin, or just take the key out
aris_unlimited
Car: 1998 Ford F150 4.6L 5 speed. Edge programmer, 2" lift, 35" tires.
The door doesn't chime if your keys aren't in it........ At least mine doesn't
_b.jaye_
Car: '03 350Z
evildky wrote:or just take the key out
aris_unlimited wrote:The door doesn't chime if your keys aren't in it........ At least mine doesn't
well, yeeeeah, but then my radio would be off!
gettin ready to cut outa work, stick my head under there & see what i can find out
bmike818
Car: 2007 Z
get a portable radio
....I will laugh if you lock yourself out because you removed the *ding *ding...
_b.jaye_
Car: '03 350Z
thanks mike ... never lock w/o the fob, so you may be in for the big letdown, although, im sure ill leave my headlights on atleast once. lol
nah, like i said, im not removing it, im switching it. as in, a push button switch. push once, it opens the circut, no chime. push it again, & everythings back to good
for anyone that cares, i did find the lil bastard. its in the back of the gauge cluster right behind the 5000 RPM mark on the tach.
Modified by _b.jaye_ at 11:09 AM 8/20/2009
evildky
06 Nissan 350Z GT
get an I pod
or turn up the stereo untill you can no longer hear the ding, or the neighbors callt he cops, whichever comes first
bmike818
Car: 2007 Z
good find, post pics of the location if you can. Who knows someone might want to put a light to go with that chime....you know some peeps are forgetful
Return to “350z / 370z Discussion”
