SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Tue Dec 27, 2005 8:31 pm
Don't give me any chit about you don't feel like searching. All your answers are there. You just have to be able to read them.
Those offsets and sizes will clear coilovers no problem. You should be using 215/45-17 on front but whatever, your car, your problem.
Does your tire tuck under the rear fender now? How much camber now?
By saying you'll be getting coilovers and then asking if anything will rub, you must plan on absolutedly dumping the car. Poor idea but it's your car.
As you compress your suspension by lowering the car too much, your wheels tilt inward. Negative camber. This allows the tire to tuck under the fender sheetmetal. If you have no rubbing issues now with the 245/40-17 you're fine You'll have to keep from overlowering your car later, but by all means, SEARCH!
