dont understand
89TN240
Car: 89 240sx hatchback
ok first off let me say i just bought my first import like 2 months ago i just got out of the minitruckin scene so the ever so popular search more response wont work cause i don't know how to search for everything. my first question is will a sohc transmission fit a dohc motor ?secondly i was reading a topic about fmu's and fpr's my quesion is do you just add the ratios up and crank the fpr to said number or what and how does the fmu work?. i hate to ask the same quetions other people do i just don't understand all the answers that have been given.
Lopin18
Car: '89 Nissan 240SX Hatch KA24E
dont understand why u posted this in the ka24et section, but i guess........... someone.............. will........ help.... maybe. also you realize that googling fuel management unit and fuel pressure regulator will actually give you all the info you need? and searching for "sohc dohc transmission swap" will get you posts about it????? Hmmmmmmmm, right now i dont have time but someone will help
DevilMB3017
Welcome. I'm sure you're posting in KA-T since your asking about turbo-charging your KA24E?
I'm sorry I can't answer you about the transmission thing, but the FMU I can.
An FMU is sometimes called an RRFMU, or Rising Rate Fuel Management Unit. Using the stock injectors it will increase the fuel pressure for every pound of boost, through vacuum sources. Most FMUs used in KA-T are 8:1. Retaining the stock injectors allow for the stock computer to be used. For a T25 or similar turbo running 7-8 lbs of boost, this is perfect - with a small timing retard to be sure.
The FPR is the fuel pressure regulator, and this just makes sure the fuel pressure stays correct within the rail coming out of the fuel pump. Your still going to need a bigger fuel pump to handle it. The stock FPR will work as long as it's still good.
If you keep searching, you'll find all these answers on NICO
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
The trannies from a single cam will mount onto a dual cam motor they are basically the same thing i know this because i used a single cam transmission on my convertible which is a Dual cam
89TN240
i just didnt understand why a fuel pressure regulator is needed if the fmu bumps the pressure up and i was told that the t25 was 2 small for a ka true or just thier opinion?
DevilMB3017
With the fuel pressure regulator, it would just flow right through the system without any pressure. The FPR goes at the end of the fuel rail iirc, and makes sure the rail holds pressure - otherwise it flow right back into the tank at no pressure.
A T25 is small, yes. But it will work for a 7-8 lbs of boost setup with an FMU pretty well if your looking for a little power boost and nothing over ~220ish rwhp.
crzycav86
Car: 93 Nissan 240SX KAT
i believe everything devilmb said is correct.
plus, the transmissions for sohc and dohc are the same.
you don't want both an aftermarket fpr and fmu - you don't need both. for fuel, you can either get an fmu or bigger injectors. bigger injectors are prefered, but then you need some electronic hardware to control and tune. fmu's won't affect your off-boost performance, although it's still recommended to get some tuning hardware.
it sounds like you're trying to do things cheap, so get an fmu. it will work well with the t25 on less than 10 psi.
if i remember about this thread tomorrow, i will show you how to choose the proper fmu ratio.
crzycav86
also, the searching can be difficult. when you're searching, put in certain keywords that you think a member would have used if he were posting the same question... something like "sohc transmission dohc same".
i used those keywords and look what the first thread was: zerothread/350981
89TN240
i wasn't going for cheap more like simple cause like i said i don't know alot about all the different types of tuning. i mean i would much rather go all out. i just got to figure out what the best setup is going to be for a daily driver.
