evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Dec 09, 2006 6:29 pm
well if you turn the key and nothering happens first place to look is battery voltage, try jumpstarting the car, if nothing changes check for voltage at the trigger wire for the starter, if you're getting plenty of power and a trigger signal you'll need a new starter, if your not getting trigger signal, it is likely the ignition switch
