dont know what wrong with my zenki
wilfonzo
Car: s14
car: '95 240sx
problem: left front rattle, can be felt in steering, happens when i hit bumps especially around turns, kinda feels like the wheel is going to fall off
thought it was the tension rods, replaced them with new adjustables with pillow ball mounts... resulted in no change
tie rod ends appear to be in good shape
what else should i look for?
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
check if ur lugnuts are bolted up tight...that happens if u have loose wheels...if its not that i wouldnt noe..
wilfonzo
Car: s14
definatly not that, but its kinda the same noise... anyone think it could be ball joint? or maybe inner tie rods? how do i check those?or may it even be just worn out shocks, this thing does have alot of bounce to it, and 177k mi
JeromeS13
Car: 2008 Subaru Impreza STI
Get the front of the car off the ground. Grasp front and rear of tire and shake side to side. If it has play, its the tie rods. Then, grasp top and bottom. If you feel movement there, its probably the ball joints.
wilfonzo
Car: s14
i did the side to side before and their doesnt seem to be much play but it does move the other wheel + steering column, this is normal right... i will do the up down as soon as it stops raining
JeromeS13
Yes, its normal. Next time you do it, make sure the column is locked so that it doesn't move as much.
wilfonzo
Car: s14
good call i didnt even yhink of that, i was going to have someone hold it, yes i am mentally hadicap
gepeto
Car: 1995 S14
Maybe your front shocks have some kind of lateral shaft play , which is usually death for shocks..
Logan76
Car: Junk
could it be a wheel bearing?
wilfonzo
Car: s14
thought it could be that too, how do i check for that... to fix it i would have to get a shop to press them in right?
Logan76
Car: Junk
unless you have a press yourself i belive? i always get my buddie he works at a dodge dealer, but has an SR powered drift car to do my bearings and stuff that im too noobie to do haha.
JeromeS13
If its a wheel bearing, it will have the same amount of play in all directions. And, you won't see movement anywhere else. However, a wheel bearing will typically give you an audible noise before it develops free play.
Logan76
Car: Junk
yeah he said it was ratteling but usually is more of a humming noise...if u hear a loud humming comming from ur front wheel that ur having problems with its most likely wheel bearings.
wilfonzo
Car: s14
yeah i havent heard any humming noises but i also havent had the car that long... i still have to lock the wheel and check for play these 12hr shifts dont leave much time to fix the 40
any chance its a blown out shock?
wilfonzo
Car: s14
well i think its the tie rod when the tires are on the ground i push on the left side one with my foot and there is some play on the left but not the right.... so this means its the tie rod?
