Vegascorbin »
https://forums.nicoclub.com/vegascorbin-u82093.html
Thu Oct 16, 2008 9:26 am
Not real sure what you are asking.
That said, if you relocate the battery you need to re-connect everything at the new location that was connected at the old location. To do any different will require extensive re-wiring.
Not to be a smart a@@ but if you have to ask then the re-wiring is probably beyond your skill level.
Just run wires from the new location that you can connect to the old wires at the old location.
Use the same size wire or larger. DO NOT USE SMALLER WIRE. (Larget the number the smaller the wire: #18 AWG is smaller than #14 AWG)
Good luck.
