donated 97 j30 what can I use?
dvldrvr
Car: 1991 nissan 240sx se
Was recently given a 97 j30 an was wondering which parts fit an s13
waxdnuggz
Car: 90 240sx hatch SOLD
91 240sx hatch SOLD
92 super sweet daily (freezing cold a.c., working ps and pw)
93 240sx hatch SOLD
94 240sx vert SOLD
Front brakes and rotors if you 5 lug or Re-drill them. The diff. If you want to do the work the 5 lug as in machine the front hubs and swap everything for rear. Other then that its useless.
PapaSmurf2k3
Site Admin
yeah the rear diff should be a limited slip unit. Definitely keep that. Maybe see if you can somehow fit the seats in?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Keep the RLCAs as they're the same as S14 units and anyone doing an S14 rear subframe swap could use them. The RUCA is stouter unit than the S14 RUCA, so if you haven't upgraded to adjustable RUCAs, you could always snag those.
dvldrvr
The entire rear is Goin in
All j30 have a vlsd
The sub frame is available locally here in fort worth
Not gonna use it
Was actually wondering if the front uprights fit if I use the lca as well
Hijacker
'94 F-150
The front suspension is a weird setup. You won't be able to utilize the front knuckles/hubs as they're completely different from the 240.
The rear subframe won't fit as it's HUGE compared to the S13.
I measured it around an inch and a half wider than the S13's. Which is about right. The J30 track is an inch wider than an S14's, and the S14 is 10 mm wider than the S13, which equates to a little less than an inch and a half. What I did end up doing is chopping up my J30 frame and welding the reinforcement plates from it into my S14 frame.
dvldrvr
Wow I've heard of the j30 suffrage fitting w offset spacers did know it wouldn't work for my s13 I meant everything but the sub frame sorry soo I'm gonna need something for the front thanks hijacker
waxdnuggz
91 240sx hatch SOLD
93 240sx hatch SOLD
94 240sx vert SOLD
There's a right up on how to use j30 front hubs for a 5lug swap. Its alot of work but if you have access to equipment then go for it if its cheap enough for you. Also no one mentioned the wheels are probably worth 140$ to someone as drift spares or needing something to roll around on.
