numbnuts240 »
https://forums.nicoclub.com/numbnuts240-u42843.html
Fri Oct 30, 2015 11:46 am
so my 2001 explorer sport needs to go. it runs, but it's got a bent intake valve (spark plug change gone wrong) and it should have a timing chain job done before the guides give out (the tensioners are already causing chain rattle at start-up). i will not be fixing it, as it's not worth my time or money. i've already purchased a replacement explorer and will be scavenging parts to swap over to the "new" one this weekend. the 2001 will be left complete and "running" except it'll be missing the radio.
i know it's worth nothing, but i would like to get the highest return possible getting rid of it. so my options are bring it to the scrap yard/junk yard for maybe $150, sell it privately for idk what, or donate it for a tax credit. idk much about donating vehicles, but i do know it''l be the easiest and quickest way to rid myself of it. what do you guys think?
2001 ford explorer sport
210k miles. like i said, it will start and run, but it will likely need a rebuild or a swap.
black exterior. paint is not in the greatest condition at all, and there's some quality rot starting at the top of the rear wheel wells.
gray interior. it's gray. behind the rear seats is trashed
auto transmission, trans cooler is leaking
4wd, works fine
disc brakes all around, one rear caliper is leaking
power sunroof, no issues
what i'm keeping:
wheels and tires
shocks
stereo receiver
plugs and wires
abs sensor
probably a couple other things i randomly think of while i'm swapping things over
