don't hold the TCS button while starting a G37
joe603
Car: 2014 Durango R/T
Well it's not that big of a deal...but if you hold the TCS button to disable it, the car freaks out and has a few warning lights illuminated on the dash. The weird one was the parking brake light!? :gotme
Anyway, just something I noticed on my 09 G37 Sedan.
I had to turn the car off then start again to clear. Nothing damaged or anything...just weird!
370Z/28
Car: 370Z & Z28 *SOLD*
'13 Lexus IS250C F-Sport
You pushed it's buttons the wrong way. :chuckle:
I have some people that do that to me. ;)
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
just curious, but was this an accident?
audtatious
So, holding the VDC button in causes "something" to happen? Wonder what that something is?
joe603
I was just in a hurry leaving somewhere and held it down quicker than I normally do. Didn't do it on purpose...
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
joe603 wrote:I was just in a hurry leaving somewhere and held it down quicker than I normally do. Didn't do it on purpose...
i dont mean to question you so much, but why would you have held it down while starting it to begin with?
joe603
eh, didn't even think about it. Just thought I'd share my findings.
zozoka1212
Car: 08 Infiniti G35x
I am sure that disables it more than normally do. All cars have different stages. This could be one. Maybe I should try it and drive it that way. Oh yeah.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
so u never actually drove it like that... i wonder what would happen.....
zozoka1212
I drive it with off all the time but not this way. I will test it out. Today is not a good day to play around. It is foggy. Couldn't see the front of the car the way home from work.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
i only turn it off when i want to play. and after my episode i had when trying to do the video bypass, i think i will leave my car alone for a little while. haha.
audtatious
The only time mine is on is when I'm traveling on the highway or there is bad weather.....
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
is there a way to default it to be off?
joe603
timmy0257 wrote:is there a way to default it to be off?
yup:
http://www.kptechnologies.com/products. ... 37%20Sedan
scroll down to the Traction Control Memory Module.
zozoka1212
K I tried it and for me it works like normally do. No funky lights. Nothing. Maybe because it is an X and the ECU is different.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
zozoka1212 wrote:K I tried it and for me it works like normally do. No funky lights. Nothing. Maybe because it is an X and the ECU is different.
Joe has the Midas Touch
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
Its an x. Could it be an easter egg to turn off awd and be rear wheel. heh
audtatious
Until someone gets it to happen then who knows.
Joe, give it a whirl and report back :)
Hell, it's still under warranty if there is a problem :gapteeth:
zozoka1212
Fezzik wrote:Its an x. Could it be an easter egg to turn off awd and be rear wheel. heh
It is easier than you think. The awd module is beside the ECU. You can take one of the wire of install a switch and you have yourself a RWD car when you need it. Mind you when you turn the swicth off you'll have an Xmas light on your dash. But when you turn it back on all is good.
audtatious
Has anyone figured out how to bypass the system so you can do brake stands (or actually heat up slicks at the strip for that matter) in an auto?
joe603
I just tried it again and it didn't do it...weird. I was parked on a pretty good incline when it did it. :gotme
Mudgen
Car: 2011 Graphite Shadow G37x sedan (Jezebel), 2011 Dark Gray Metallic Subaru WRX sedan (Darth), 2006 F150 XLT 4x4 5.4L 4OT (Big Brown)
^Check your brake fluid.
joe603
Better be good...car has less than 10k miles!
Mudgen
OK. Just mentioned because I saw a post elsewhere about crazy warning light behavior from bf being an ounce low.
zozoka1212
BF low comes usually with brake,VDC and slip lights. Also usually do it first when you accelerate hard or stop hard. This was I think due to the incline you were parking.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
joe603 wrote:Well it's not that big of a deal...but if you hold the TCS button to disable it, the car freaks out and has a few warning lights illuminated on the dash. The weird one was the parking brake light!? :gotme
I bet the car thought the switch was not plugged in.
Within the first few seconds of starting the car it will run a myriad of self tests on switches, sensors, and circuits. If one of the sensors returns a an irrational (to the computer) reading it may freak out the system. If one system freaks out the others on the network are soon to follow.
The reason the BRAKE light came on was that is the warning light for the entirety of the antilock brake system. There was a fault stored for a VDC switch position error.
The normal driver would not the VDC off switch to be held while starting the car.
What does the 09 do differently with the VDC off?
The throttle cut logic usually kicks in quite quickly (thanks Toyota for making them do that....)
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
funny how joe says "dont" do this. then everyone tries it
zozoka1212
LOL tell your kids not to do anything and you can bet all your money on it they will try it.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
zozoka1212 wrote:LOL tell your kids not to do anything and you can bet all your money on it they will try it.
no doubt
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
audtatious wrote:Has anyone figured out how to bypass the system so you can do brake stands (or actually heat up slicks at the strip for that matter) in an auto?
install an old school line lock switch?
Then you don't need the brake pedal to burn out?
On the Ram if you pulled the ABS fuse it pretty much killed the traction control, that was how I heated my 325/45/18 M&H Racemasters before a run.
