DON'T FORGET the NISSAN ONLINE MECHANIC section
PalmerWMD
Car: 2004 350Z
Thats where the repair + diagnostics questions are supposed to go."Technical" is more for mods 'n stuff.
We have master ASE certified and factory trained technicians in our NISSAN ONLINE MECHANIC section.
So Post those other questions here:
zeroforum?id=23
Fred...
Amaya
Car: 1993 Nissan 240sx se
I had a question if I have a 1993 240sx se (Ka24de) can I replaced it with a 1995 Ka24de engine. I would appreciate some information. [email protected]
Absolutely. It's a simple swap, as the engines are identical.
I'd recommend you ask this question in the 240sx section just to make sure you don't need to swap the ECU.
Welcome to NICO!
kinkymike
Car: 93 240 sx se
first time post so excuse the noobness lol
hey ive got a 91 240sx with a ka24de with busted pistons, i came across a frontier with a ka24e as the block are the same but the pistons are slightly diferent (in the ka24de the have a round end the the ka24e have a flat head) would it be a problem if i use the flat heads on the ka24de?
thx for ur time
ps; congrats on the kick *** forums
flewhuey
Car: 1991 240 SX Hatchback
Where can I get a comprehensive but concise histoty of the 240sx series; engine, drivetrain, suspension and body layout and major details?
Such as:
What does S13, S14 etc represent?
Which model years had which engines; i.e. CA, KA, SR, etc. and what they represent?
What are the basic suspension arrangements of the various model years?
When did "styling cues" change, and what were they?
Omega47
Car: 89 240sx Coupe
Just put in a digital cluster,cause previous owner decided to go analog..My car is an 89 240sx SE but has an SR20DET in it,i swapped the tach out so that works,the engine and saftey lights,temp and fuel gauges,work as well.Problems:Cluster illumination goes off once and a while,,,Interior lights do not turn on...Stereo does not work...Door open light stays on and flickers when doors are closed and car is on.Some insignia lights such as hazards or defrost are not illuminated...Auto seatbelt dont work unless key is to ON position...Clock lights up when i turn lights off...Clock shuts off and resets when door is opened...FUSES ARE FINEIm so frustrated atm... Any Help is greatly appreciated.
Modified by Omega47 at 12:26 PM 3/29/2006
Mike, Huey and Omega:
Please post these questions as NEW threads, so that they will be seen. All three are great questions, and I'm sure there will be lots of good answers forthcoming.
Welcome aboard, guys!
onpoint357
Car: 240 sx
were is the fuel pump relay located on a 91 240sx
drifterz73
Car: 1989 240sx coupe/w auto and 1989 240sx f/b w/ man
i have 89 ka24e and it is having a idle problem , usually in morning start up then die kinda hard sometimes then it just idles very rough .. when it gets warm it does ok.. sometimes it surges in 3rd about 30mph .. replaced maf, noticed no vacuum leaks ... .. any ideas please.. oh has about 188k but runs well ...
drifterz73
read my post please and help if you can...
WideBodyCharlie
Car: 77 Datsun B210, 74 pl620, 98 Frontier, 94 Altima, Nissan Cube
hi-i have a 1990 240sx with a rb20det motor. i recently hot-wired my electric fans to run of the fuel pump fuse{ a write-up from this site, you run the positive wire to the fuel pump fuse and you ground the negative} well it has shorted out the fuel pump i think. the car sputters and will not run. anything i can do to at least make this thing run to my shop or somewhere? thank you. one guy says i need to rewire my fuel pump now??? just thought i would add that
dunneright595
Car: nissan 240 sx
so i just finished changing the head gasket in my car its a 89 240 sx sohc and i went to turn it over to hear it rore and it jsut wount start it wants to makes all the noises to start but wount kick over i check the plugs and there in the right order and i took out the ac while i was at it but i dont know whats not making it fire im not mechanically inclinded so im not sure what to look for or at to see why its not starting
nuknght
Car: 1991 nissan 240sx w/ ka24de
91 nissan 240sx ka24de. Car won't start......swapped around relays, checked all fuses, thought it might be the starter/ solenoid...had tested but tests good..tried hotwiring and nothing. what am i missing?
driftkurd
Car: 92 nissan 240 coupe
hey guys whats up hey this is my first time posting and here is my car
Weezer
My question is: My 240 recently started making a sputtering noise when I am at a stop, i have to keep it reved over 1000 rpms, and it starts acting up around 850 mwhich is normal idle. Oh, and my brakes are getting harder to push in for braking stops.
*Does anyone else a problem with their 240 all the time because its something new every week, and I'm thinking about selling it*
nuknght
First to answer your question regarding the 24sx.....I always have problems with My 240. But the good outweighs the bad....theoretically. I love my car to death even though it ticks me off most of the time. 2nd....i had that sputtering problem a couple of times with my car.....if you have an auto (not to sure if its the same with manual), check the vacuum line that runs along the firewall between the brake booster and the intake manifold. make sure it is fitted together properly. if there is too much tension. remove the braket that holds it to the firewall.. When your out "hot rodding", because you have hydralic motor mounts the motor tends to rock and separate the hose from the fitting on the firewall. removing the bracket eliminates this.If your hose is seated properly.......then it might be time for a new brake booster.Caution on used parts---- I ordered a used brake booster and it lasted me 4 months. hope this info might be helpful to you.
FIA28950
Car: 1991 240SX SE
hi i posted 91 transmission questions with some new questions yesterday but have gotten no response. could you offer your ideas or if need be you can email me at [email protected]. i look forward to your reply.paul cass
