DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Fri Sep 02, 2005 11:57 am
now it idles like a dirty poop too. And by idles i mean runs. Its running like either the ignition is retarded a lot or the EGR is stuck open.
My other car used to run and idle like this (a lot of shaking, and like no power), but after i got a chance to get on it wide open for about one second it would all the sudden surge and run perfect. It however no longer does this. From my best guess based on the symptoms and the fact that WOT made it go away, i assumed it was a sticking EGR, but it NEVER does this anymore.
very confusing problem. new plugs, swapped wires, unplugged knock sensor, unplugged TPS and messed with the distributor. tried a lot of stuff, but the only thing i was too frusterated to try is hitting the EGR with a hammer to get it unstuck (which is one of the best ways to check for stuck EGRs in my experience).
only thing i can think of is maybe i accidently put the S14 coolant temp sensor in instead of the S13 one, but i dont think thats the case, all i need is an idea if someone has one
