Don't call me stupid but....
crazeddriver
Car: upgrading my car
I have a simple question so please do call me stupid. What is the difference between coilovers and lowering springs?
[s3]
http://www.search.com
Springs usually not adjustableCoilovers usually offer many levels of adjustments
ziggy682
Car: 1991 240SX Turbo
A spring is just that...a spring.
Coilovers are a spring, shock, and usually a threaded body that is adjustable for ride height. Usually they shocks are adjustable as well.
Ground Control also sells springs with a threaded collar, so they are kind of like coilovers minus the shocks. If you pair them up with some adjustable shocks, you basically have a coilover.
Here are some coilovers.
http://store6.yimg.com/I/racerwheel_1768_36229609
First site I came to when I typed in "coilovers" into Google.
Nathan
Wow, another Denton person! You wouldn't happen to be at UNT would you ziggy?
/threadjack
ziggy682
Nathan wrote:Wow, another Denton person! You wouldn't happen to be at UNT would you ziggy?
/threadjack
Well, I live in Denton, but I don't go to UNT. Actually, I'm moving to Colorado in a week, so I won't be in Denton much longer. I'm looking forward to some twisty mountain roads. There just aren't any fun roads to drive on around here.
C-Kwik
Technically, a coilover is nothing more that a spring over the shock combo, whether the ride height is adjustable or not. The term is popularly used to describe a ride-height adjustable coilover though. Semantics.
However, the advantages of a ride-height adjustable coilover are that they allow you to set ride-height a little more carefully and allow you to adjust the cornerweight balance to optimize handling. If tou get a set that has adjustable damping, you get the benefits of changing the shock valving some as well.
Candymans240sx1
I bought Racingsport1 (or something like that) coilover kit with the sleeves. I put them on and in my opinion they were no better than cutting the stock spring oldschool style. Unless I did something wrong...save up and buy the GOOD ones.
89S13SILVIA
Car: CARS
what part of colorado u moving to i live in arvada get ahold of me my e-mail is [email protected]
