dome lights not working
nabm37x
Car: infiniti m37x 2011
hi everyone,
so recently I tried to upgrade my interior lights to led's that I ordered from eBay, but they never worked.. so I re-ordered lights from amazon and still not working. My problem now is that even the regular lights that were there when I bought the car dosent work.. any idea of what could I do?
Also if anyone has any recommandations on led's light that I could order? thanks
(infiniti m37x 2011)
nabm37x
I would add that the lights in the back, wich I replaced with led's T10 are working perfectly fine.. only front dome that is not working at all!
Frog
Car: 2011 Infiniti M56 S
O boy here we go again. Yet another person out 3500$ You most likely didn’t disconnect the battery and fried the wire going to the overhead and foot well lights. Several people here have done it. It requires a new wire harness to be installed. Search this forum. It’s all over
Larz
Car: 2019 Q70-L RWD
OK easy stuff first. Not all that likely, but check the fuses on the lower drivere side to make sure none have blown. I reckon the dome light does NOT have it's own fuse and other lights would also stop working if it's a fuse, but it couldn't hurt to check anyway.
Second, check the actual bulb housing to make sure it was not damaged and is making proper contact with the bulb.
Failing that, take it to the dealer for your next oil change. Tell them the dome light has stopped working. They will likely NOT charge you extra to inspect the dome if it's already there for another service.
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
Larz wrote:
Sun Apr 07, 2019 8:25 am
Second, check the actual bulb housing tro make sure it was not damaged and is making proper contact with the bulb.
Agree with Larz, best case scenario is that it's a fuse, but behavior of your problem prolly points away from that.
Unfortunately, something that seems as simple and easy as swapping your bulbs to LEDs in an Infiniti has caused some major issues in a lot of guys' cars: the bulb sockets/electronics are exquisitely sensitive. I burned out a wire harness swapping bulbs (fortunately fixed under warranty. IIRC one of the other moderators, Ilya, shorted out his BCM (body control module) doing something seemingly innocuous with his bulbs too.
Take home point: always disconnect your battery before doing anything electrical on your Infiniti even if it seems trivial - kind of a pain, because you have to reset your auto down function of your windows and readjust your sunroof, but may save you a multi-thousand dollar headache especially if you're out of warranty.
