Silver Eagle »
https://forums.nicoclub.com/silver-eagle-u172137.html
Wed Dec 22, 2010 11:38 am
Being from Scotland I am not sure what you mean by dome light, if it is what we call the cabin light that goes on and off when you open and close the doors then I had that problem in a previous car. Replaced the contact switch in the door, still failed, replaced the Cabin light "Dome light", checked and tested the wireing door switch to light and fitted the light (which I picked up from a scrapyard ) all was well. The problem was found to be a relay which kept the light on for about 15 seconds after you close the door. This may not help you with your problem only to say that, that kind of fault is not unique. I would think a decent mechanic should have be able to find the fault, could even be as simple as a bad earth, it is not rocket science.
