B Serious »
https://forums.nicoclub.com/b-serious-u28890.html
Sun Apr 02, 2006 9:20 am
Verts have lights up near the windshield near where you pull down on the top to lock the sides. However, there are no switches on the light itself. For that matter, the only thing that turns the light on is the door switch.
I took the cover off but didn't see anything obvious (corroded wires, bad connections, etc). I've also completely removed the door switches (one at a time and both at once) - but, though the light didn't come on when i opened the door, it DID come on over the bumps.
One thing I recently noticed is that it will come on every time I turn to the left up an incline (hill, bump, whatever). I'm not sure what that means but it happens.
are there any wires in that bundle that travels between the body and the dust protector right there by the front driver's side wheel well that could cause a short like this? I had some trouble with my suspension and the tire ended up burning through the protector and fraying a bunch of wires (which caused some other problems with things like my windshield wipers). I fixed the problems and rewrapped the wires so I shouldn't have any other problems due to that - but the turning left up an incline would argue that I might.
Thanks in advance for any helpJ
