Dome light and Map light not working.help please
Rargetni
Car: 1997 240sx
Hey guys, so i tried installin my key ring light. I wanted to power one wire to the red wire thats on the ignition cylinder. The other ground wire accidently touched the power wire-- it liked slipped and touched causing a spark. So now i have no dome lights or map lights and the bulb obviously wont work if i try to power them. I haven't had a chance to check the fuse box cause its dark out. Do you guys think it would be a fuse problem. or maybe i burnt a relay or something? : . any input would be appreciated
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Hopefully its a fuse problem so check the fuse box(es).
Rargetni
Car: 1997 240sx
ive check all fuses they all seem to be good. i found that the 100amp fuse looks a bit dirty/blown lookin' but if it was wouldnt it mean that my car wouldnt be able to run?
Aoshi1
Car: 1995 Nissan 240sx
Did you replace the fuse? If so, what happened?
Rargetni
Car: 1997 240sx
No i didn't replace any fuses because they're all good. i would assume the car wouldn't be able to start up without that 100 amp fuse. My door chime and interior lights wont work..any guesses?
csimp3
check the 75 amp alt. fuse
