How do you install the resistors to get the lights to completely shut off? My dome and map lights give off a dim light. I find it annoying - and people asking about it is even more annoying. I've been searching for an answer like crazy but no luck... I just keep coming across threads that say "install resistors" but none of them mention how. Thanks for any help!
****EDIT*****
I know we aren't supposed to link to competing forums, but what about non-competing forums? ....
After a lot of searching I found a solution for resistors on the 3175 dome light bulb here :
http://forums.vwvortex.com/showthread.p ... -Installed!
And for the 194 map lights here:
http://www.cobaltss.net/forums/how-guid ... rs-237103/
Any foreseeable problems with doing this? And they reccomend two different types of resistors (1watt, 100ohm and 1/8watt, 1kohm). Are these specific to the vehicle or the light bulbs? Do I use those resistors or do I need something different?
