Doing oilchange. Anything i should know?
SR20Drif
Car: 1992 Nissan 240sx
I Just bought Mobile 1- 15w-50 oil and a oil filter. I still need to get my spark plugs but im no sure which one to get. I want the NGK ones but ive seen two part numbers (BKR7ES11) and (BKG6EIX) im not sure wich one to get. Also what should i set the spark plug gap at?? I've also seen two (.28) and (.34). Which one?????
SR20Drif
Oh yeah i have an sr20det redtop
yellow_jacket
Car: 95 240sx
After doing the oil change, disconnect the cas, crank the car til you have oil pressure, then hook the CAS back up and fire the car up.
Got13oost
Car: Kouki S13
Whats a CAS??? and where is it located at?
own3d
Car: 95 FD3S
The cam/crank(forgot which) angle sensor, its at the very front right of the valve coverif you can find it just disconnect the plug wires and crank it, basically you want to turn the engine over a few times before acctually starting it.
Got13oost
Car: Kouki S13
On front of the Engine on the top right side??
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
I would also like to know the right plug gap,I have my set at .30 now.The CAS is right on top of the water neck,The front of the valve cover on the right if your standing in front of the car.
DawgMode
Car: 180sx
this is the CAS...
tubakins
Car: 89 240sx fastback
you dont have to do all that, just prime the oil filter when its off
240sxhoe
Car: chicks. gym. beer. er.... 240sx?
LOL u guys are freaks. its just an oil change, this engine comes stock in japan. wtf.....
Got13oost
Car: Kouki S13
aHH ICIC, i like that pik i wish my engine bay was that clean ~!!
yellow_jacket
Car: 95 240sx
The oil filter is a sidemount unit. You cannot "prime" it with the filter off.
Any any mechanic who knows what he is doing will never start a turbo charged vehicle with a dry oil filter.
SR20Drif
how would u know when u have oil pressure?? Also what should i set the spark plug gap to?
own3d
Car: 95 FD3S
240sxhoe wrote:LOL u guys are freaks. its just an oil change, this engine comes stock in japan. wtf.....
yes it is just an oil change, but its how your supposed to do an oil change on a turbo'd car.
btw we primed my friends oil filter and he has the greddy relocation kit so the filter sits upside down, just gotta be fast!
SR20Drif
How do you prime the oil filter?? and whats the spark plug gap?? dam... im soo new to this...
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
unplug the Crank Angle Sensor (CAS) and then crank it over for a good 10-15 secondsthen wait 20 seconds, then do it again.
tubakins
to prime the filter you just put oil in the filter ontill its full and carefully put on the filter on and try not to spill.
SR20Drif
F*CK MAN... Ok i did everthing accept for taking off the oil filter cause its a b*tch!! I tried all the tools but thry didnt work. Now what??
flohtingPoint
Car: 2004 Z16 Corvette Z06
Make sure to unplug the ground from your battery, unless you want to toast your alternator.
To get the oil filter off in the stock location, stab it with a screwdriver to release pressure and remove. Its the only way I could get mine off before I did the filter relocation.
chickentendah
Car: SR20DET Hatch
flohtingPoint wrote:Make sure to unplug the ground from your battery, unless you want to toast your alternator.
Why would you want to do that? Are you referring to oil spillage into alternator and subsequent short-circuiting?
Luke
I had to find a oil filter wrench socket which went right around the filter. I found that's the easiest way to get at that thing.
Why aren't you using 10w-30? You're in CA, and you'll need more viscosity for the hotter weather. Factory spec is 10w-30 instead of 5w-30 I believe. I run Mobil 1 15w-50 when it starts getting hot.
